Void where stereo should go
Postby wellingtondane » Sun Jun 18, 2017 7:09 pm
Not meaning to sound thick but bought a single din kenwood and a single din adapter surround. Mk5 1998. Went to fit it today but seems to be a problem am i being thick. The void where the original stereo went is massive with no top or sides to fit a new stereo as there would be 2 inches on sides and top and an inch under it, in other words if i did put a stereo in what i have it would disapear backwards. Is there something which has been removed.
wellingtondane
Re: Void where stereo should go
Postby ake » Sun Jun 18, 2017 7:24 pm
Sounds like some idiot has butchered the hole!
The adaptor should fit snugly in place
Postby wellingtondane » Sun Jun 18, 2017 7:32 pm
The front adapter plate vits but nothing behind itjust big cave
wellingtondane
Postby ake » Mon Jun 19, 2017 7:15 am
wellingtondane wrote:The front adapter plate vits but nothing behind itjust big cave
That's ok
Postby wellingtondane » Mon Jun 19, 2017 9:16 am
Nothing to secure the stereo to though
wellingtondane
Postby Mike » Mon Jun 19, 2017 11:26 am
wellingtondane wrote:Nothing to secure the stereo to though
There should be a hole at the rear of the void that a rubber 'thingy' on the back of the head-unit locates into.
Mike
Wind up merchant!
Postby wellingtondane » Mon Jun 19, 2017 5:20 pm
Here is view from the front showing the bottom the top and the sides
wellingtondane
Postby Mike » Mon Jun 19, 2017 5:51 pm
wellingtondane wrote:Here is view from the front showing the bottom the top and the sides
Third pic, there's a bracket at the top, about an inch wide with chevron type shapes in it, that supports the headhunt. Ignore what I said about the hole for the 'thingy', I must have been thinking about a different MK.
Mike
Wind up merchant!
Postby ned » Mon Jun 19, 2017 6:01 pm
Yes there should be a plastic thing either on or you bolt to the head unit than slides on the things Mr Mike said about.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby wellingtondane » Tue Jun 20, 2017 3:03 pm
Right i get it now, What bolt do i use, the surround came with a plastic thing which i see hooks over the thingy above and then between the aluminium box at the back of the head unit
wellingtondane
Postby Mike » Tue Jun 20, 2017 3:25 pm
wellingtondane wrote: What bolt do i use,
The thread and max bolt length is normally stamped into the head unit next to the threaded hole.
Mike
Wind up merchant!
Postby wellingtondane » Tue Jun 20, 2017 4:30 pm
Thanks have got a little bolt and will fit it later and post up a pic,
wellingtondane
