V6 swap into pinto mk3
Postby CLIPBOARD » Tue Jun 20, 2017 11:37 pm
So I have a mk3 190 camper with a 2.0 pinto, it currently returns 17mpg and tops out about 65mph (gps - the speedo shows 80) and virtually comes to a standstill at the sight of a hill!
I also have a 2.9i Sierra lying around that has lost the battle to tin worm but the engine is still strong, seeing as this has (or rather had according to ford) about 150bhp and the pinto a mere 74 I was hoping to drop it in.
The pinto is on an MT75 gearbox with an adaptor plate
The wiring for the EFI I can sort, but I'm struggling on a few of the mechanicals:
1. I understand that I can redrill the 2.0 pinto gearbox mounting plate to take the 2.9 - does anyone have a template?
2. Engine mounts, do I use the pinto transit or the Sierra V6 mounts?
3. Flywheel and clutch - needs to be SVO? Anyone know where I can get one from or an alternative
4. Anything I've overlooked?
CLIPBOARD
Re: V6 swap into pinto mk3
Postby dumper » Wed Jun 21, 2017 12:54 am
I think some of the mk3 Ambulance had the v6 in them maybe you can find one in a breakers yard
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby andz327 » Wed Jun 21, 2017 12:09 pm
I might be wrong but I'm sure the transit box had a larger belhousing on it hence the plate and I think the belhousing will fit the v6, as for the engine mounts I can't say maybe trial and error, or as above and old ambulance would be ideal
andZ3 Sony Z3
andz327
Postby andz327 » Wed Jun 21, 2017 12:14 pm
Maybe messaging this guy on the bay might helpImageImage
andZ3 Sony Z3
andz327
Postby DodgeRover » Wed Jun 21, 2017 10:56 pm
Ford put the 2.9 in in a strange way, thick adaptor plates one off flywheels etc. it's been suggested before you could just modify the pinto plate, I think some of the holes line up.
One of the exhaust manifolds is unique to the transit as well from memory.
DodgeRover
