Hey peeps
Wondering how much it will cost for a new long engine + turbo and labour for changeover?
Van is a 2008 vm, 6speed, 2.4L turbo diesel.
Cheers.
Rockman1
Rockman1 wrote:Hey peeps
Cheers.
Rockman1
andz327 wrote:When original turbo broke engine oil was running into the cylinders and being used as fuel, thats how engine wouldn't stop, unfortunately if you dont put in gear and jump on brakes and let clutch up to stall it right away your engine would run dry of oil damaging it internally and more than likely the piston ring were badly damaged so it will be down on compression, down on power and blowing oil past the rings and oot the exhaust, new bare engine is around £2500
andZ3 Sony Z3
andz327 wrote:Just had quick look at tpuk and I think they've only got reconditioned, and low mileage engines but its not going to be cheap whatever way you go mate, you could probably buy a newer van cheaper I'm afraid... Not good andZ3 Sony Z3
knobby1 wrote:andz327 wrote:Just had quick look at tpuk and I think they've only got reconditioned, and low mileage engines but its not going to be cheap whatever way you go mate, you could probably buy a newer van cheaper I'm afraid... Not good andZ3 Sony Z3
Judging by his use of VM and kms...I'm guessing he's not in the UK...possibly Aus..?? So getting an engine from the UK would be prohibitive, even if just from a shipping point of view.
andz327 wrote:OUCH thats worse sir, rebuild it for him, give yourself something to pass the time with andZ3 Sony Z3
