Hi guys
Am after some help with a 2005 2.0di mk6 transit. No speedo EVERYTHING ELSE ON CLUSTER WORKS FINE. No codes stored. VSS is working and is sending signal to ecu, can bus signal seems to be ok (mirror image on scope). However although i seem to be getting a signal from VSS to ecu it still reads 0mph on the scanner? Could this be a fault within the ecu? Im assuming the signal from ecu is sent via can bus to cluster? Andone had symptoms like this? Any ideas where to go next? Thanks guys
