Can someone provide suggestions where I can get the correct rear brake cylinders for 1973 Ford Transit 130 V4 1.7 dual wheel ex German Fire Brigade transit. The ones I have found either have the locator pin in the wrong location or pistons heads are not flat.
The cylinder is marked on the body 99023 then another unreadable digit, followed by 0148. the outer seal is marked Lockheed 3812-738 R (E) 231.
Any help would be appreciated.
Dave
