Hi, my name is Mathew and im new here. Sorry for my English. I have a problem on my Camper Laika, with Ford Transit MK5 van. It was me causing the problem, i disonnected the socket with a lot of wires on my Lucas Epic pump, not with ignition on, but with battery still connected. I have a problem that the engine is not shutting down when i turn the key on off position, the engine is running for other 20 seconds and then shuts down, i thought the problem was the pins on the pump were not in good contact or something and i removed the socket, spray it with contact lubrificant and reffited on the pump again. I turned the ignition on and started the engine, and the red engine light is not going off, and the machine has no power at all, we have connected the OBD to the tester that showed 8 faults, that we can not erase. What i did wrong?? How can i fix that?? Hope someone can help me.
Many thanks in advanced.
