Guys hope your well,
Have a problem with my transit.
Bought it off my mate a while back as it needed a Engine.
Replaced engine (not sure if Injectors went in right way from old), changed oils and filters and it's been running fine the last 5 months.
It did have a EML light.
Took it to a garage to check. Garage said it's EGR fault.
I Replaced EGR, and plastic pipe heading down to large rubber pipe as that was clogged up and sensor full of black soot!!
Put back together, EML disappeared. Thinking this is good, took for a drive and it started knocking after 1.5mile.
Now knocks straight away.
EGR don't need coding do they.
Have bought cheap IDS software and it's installed but it won't let me run a Injector / fuel pump learn.
What you reckon.
