Sudden high Revs/loss of engine
Postby pollyfarmer » Mon Jul 17, 2017 6:20 pm
Hi,Im hoping that someone can help me with a problem with my transit lwb minibus. (please can you explain in idiot English as Im a female farmer,inner workings of livestock Im ok with,mechanics are not my forte!) whilst driving at any speed there is a sudden increase in revs (from idling at 1000ish to 1500 and rising) there is loss of power and the coil light comes on,I then have to turn off the engine and restart which lasts for a while but then the same thing happens again. We have had a diagnostic run twice by different garages but both came up with nothing,but there is clearly something wrong. I was wondering if it was anything to do with the speed limiter thats fitted,otherwise I am baffled. Please can someone shed any light on this as with my 6 children and an assistance dog in the bus Im getting frazzled with all the stopping and starting!
pollyfarmer
Re: Sudden high Revs/loss of engine
Postby Altransit » Mon Jul 17, 2017 6:45 pm
Welcome to the forum :D
It always helps with replies if you can tell us which van/engine you have :)
Postby ned » Mon Jul 17, 2017 7:13 pm
Altransit wrote:Welcome to the forum :D
I'll hazard a guess at mk6 tourneo. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby pollyfarmer » Tue Jul 18, 2017 9:31 pm
Ooops! Sorry,thought Id put that in but......its an 05,2.4,17 seater,doesnt say what model so Im guessing Im lumped in with "minibus" catagory??? :oops:
pollyfarmer
Postby knobby1 » Wed Jul 19, 2017 10:02 am
pollyfarmer wrote:Ooops! Sorry,thought Id put that in but......its an 05,2.4,17 seater,doesnt say what model so Im guessing Im lumped in with "minibus" catagory??? :oops:
Do you know if it's a TDDi or TDCi..??
Postby The tricky one » Fri Jul 21, 2017 6:25 pm
I'm having this exact same problem. Just thought I'd give the post a bump :)
The tricky one
Postby ned » Fri Jul 21, 2017 6:52 pm
Its mk6 so not all code readers will work ideally it needs plugging into ford ids.
I'm guessing its 125ps TDDI, if you give us the reg one of us can find out for you. N
ned
Postby The tricky one » Wed Aug 09, 2017 8:23 am
Just for info, I had this problem and eventually fixed it.
The fuel pump timing solenoid wires had chafed and were shorting out.
I re-insulated them and all is good.
Ids had reported crank position sensor, wiring short, open circuit and both of the standard fuel timing solenoid errors.
Hope this helps.
Btw it is a 06 mk6 2.4 Tddi with the vp30 pump.
The tricky one
Postby Altransit » Wed Aug 09, 2017 10:44 am
Chafed pump wires are more usually a FWD problem, whereabouts on the loom was the problem on yours :?:
Postby The tricky one » Wed Aug 09, 2017 12:16 pm
Hiya,
It wasn't on the loom. It was on the 2 wires from the pump circuit board (EDC ?) to the solenoid itself.
I think the wires were left too long when the solenoid was changed and it rubbed/burnt against the engine.
Cheers
The tricky one
Postby Altransit » Wed Aug 09, 2017 4:30 pm
Thanks for posting back 8)
Postby karl » Wed Aug 09, 2017 4:54 pm
great find :D
karl
Tranny Lover!!!
