VJ Transit power problems
Postby tonyinoz » Sun Aug 06, 2017 10:10 am
Hi All
looking for some pointers here.
I've got a Transit VJ 2.4 tdi 2005Australian Delivered. I've had some problems and spent a bit of money sorting it out.
It's been running really well until recently.
I've notice over the past few weeks the motor sounds a bit louder. After a recent service its sounds like its running a bit rough. plenty of power though, all good until today.
We did a big country trip ( 400k) we noticed on the way home that we have lost power and there is a mid pitch whistle coming from the motor. Seems to be OK cruising, however, inclines the van struggles maintain speed. Not stalling at all, motor seems to run fine. There have been some exhaust gas getting into the cabin in the last week and these seemed stronger this morning. Non existent on the way home. Hoping its not the turbo.
Thanks in advance for your advice.
Regards
Tony
tonyinoz
Re: VJ Transit power problems
Postby AndyG » Sun Aug 06, 2017 10:53 pm
Carefully check for split/damaged;
egr pipe
turbo boost hoses
intercooler
Postby loot » Mon Aug 07, 2017 10:36 am
And I think the seam on the inlet manifold can split too from reading previous posts. :wink:
Ids map here
loot
Postby AndyG » Mon Aug 07, 2017 11:12 pm
loot wrote:And I think the seam on the inlet manifold can split too from reading previous posts. :wink:
Plastic :?:
Postby loot » Tue Aug 08, 2017 10:48 am
Yes plastic and seam welded(iirc)
Quality :lol:
Ids map here
loot
Postby tonyinoz » Tue Aug 15, 2017 4:56 am
AndyG wrote:Carefully check for split/damaged;
egr pipe
turbo boost hoses
intercooler
You were right! EGR Pipe broken and burnt a hole in the manifold. Thankfully not the Turbo
Cheers, thanks for your advice
tonyinoz
