by ned » Wed Aug 16, 2017 2:15 pm
What actually happened when the van died?
The 2 codes you have point to pump/injectors have they been cleared since you replaced the pump and injectors?
If the 2 codes are fresh then I would be retracing my steps and checking all pipes and connection are good and not allowing air in or leaking, is the new fuel filter the correct one, when you have been trying to start the van have you got enough fuel in the tank (it'll need mire than 1 fuel can full) and have you been filling the fuel filter every couple of attempts.
You say you have fuel to the injectors, how do you know? N
