by Punto443 » Thu Aug 17, 2017 10:38 am
New bolts from ford £2:88 each, check whether the van has the modified clamps, or needs them?
Full set of seals and washers from tpuk about £25.
If it's a recon, you shouldn't need to recut seats etc.
injectors will need correction codes entered into the pcm with diagnostics, all of them if the no.s have not been noted on disassembly.
And pump learn and injector pilot on completion.
