Just had a look at the Manual for my new 2017 Custom Trend.
The rear jacking points are "under the rear leaf spring directly behind the rear wheel".
This doesn't look right.
The Ford scissor jack does not sit right on the leaf.
There is a brake line directly in the way of the jack.
The leaf 'straightens out' as the van is jacked up.
Generally it doesn't look right and doesn't feel right.
The jack could easily go under the rear axle however, but NOT according to the manual.
I'm sure a garage would put their jack (bigger than the Ford scissor jack) on the axle.
Any thoughts/advice, what do others do?
Bearing in mind I cannot get another jack, as this is a campervan with limited storage space for tools.
Hopefully, below is a photo of what I'm talking about. Jack should sit right on the 'white blob'
