Transit Custom Alloy wheel load rating ?
Postby motorman116 » Sun Aug 20, 2017 10:31 am
I like the look of the Ford Transit Custom Alloy wheel, (not as many holes / spokes to clean as the alloys on my van).. Does anyone know the load rating of them, as my van is a 350 long wheel base (Class 7) so the load rating of the wheels is checked on the Mot, also what wheel nuts will I require, as Im not too sure the custom nuts fit (I will require 2 x locking wheel nuts per wheel)...
These....
Ones on my van at the moment
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Re: Transit Custom Alloy wheel load rating ?
Postby Altransit » Sun Aug 20, 2017 11:01 am
All I know is that the thread pitch of Custom studs are different to the pitch on Mk7 studs, but your alloy nuts should fit those wheels, assuming they're both tapered :)
Postby andz327 » Sun Aug 20, 2017 11:23 am
Martyn had sets of these alloys with nuts and lockers and tyres all virtually brand new
andz327
Postby andz327 » Sun Aug 20, 2017 11:28 am
Would imagine they're the right weight rating as I've seen them on mk8s not just customsImage
andz327
Postby motorman116 » Sun Aug 20, 2017 11:53 am
Altransit wrote:All I know is that the thread pitch of Custom studs are different to the pitch on Mk7 studs, but your alloy nuts should fit those wheels, assuming they're both tapered :)
The wheel nuts are different, the alloys on my van can use the standard Mk7 steel wheel nuts if I need to (ones with the flat washer)
motorman116
Postby ned » Sun Aug 20, 2017 11:58 am
I believe the tread pattern is different between the mk7 & the custom so you'll need mk7 alloy wheels nuts. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby mrepson » Sun Aug 20, 2017 6:50 pm
the mk8 custom alloys have tapered nuts, so you need to use tapered nuts with the right tread pitch to screw on the mk7 studds,
mrepson
Postby bigjohnthomas » Mon Aug 21, 2017 9:05 am
They are the same wheels that are on that stupid guy martin contraption init ?
Always loads of them for sale cheapish
bigjohnthomas
Postby wojciech » Tue Aug 22, 2017 7:19 pm
mrepson wrote:the mk8 custom alloys have tapered nuts, so you need to use tapered nuts with the right tread pitch to screw on the mk7 studds,
viewtopic.php?f=5&t=179076
wojciech
Postby ake » Tue Aug 22, 2017 8:59 pm
The MK7 alloys were rated for the 3500kg vans, so I would imagine that these will be as well
