Spraying the Underside to protect it from Rust
Postby bclg » Mon Aug 21, 2017 10:17 pm
I was going to spray the underside of my 2007 SWB Transit with Waste Oil is this a good or a bad idea.
What would I need to thin the Oil with to allow me to spray it with a Garden Pressure Sprayer?
bclg
Re: Spraying the Underside to protect it from Rust
Postby andz327 » Mon Aug 21, 2017 11:17 pm
Stop ..... Thats nuts , just buy something like waxoil and use that
andz327
Postby dumper » Tue Aug 22, 2017 5:58 am
I've used waxoil on my van on the outside underneath on top of the Ford under seal but in the inside of the chassis and xmembers I sprayed waxoil in and when I've done a oil change I have also sprayed the waste oil in while still hot downside is the mess on the drive afterwards as excess drips out .
Has for been silly useing waste oil that's what was used for years before waxoil came on the market
Postby ABA » Tue Aug 22, 2017 4:20 pm
I did the bottom of mine with Shultz cost lest than £ 90 that was with a Shultz spray gun as well put plenty on and still had tubes left over and no mess at all
ABA
Postby dumper » Tue Aug 22, 2017 7:27 pm
To be fair Shultz does not stop rust it just covers it up and traps in the rust
Postby mattt429 » Tue Aug 22, 2017 8:50 pm
I cleaned the underside of my van and all arches back to good clean metal.
No mud
No oil or grease
Remove any loose flaking material
i then applied a rust proof primer, then used hammerite underseal with added waxoil, jobs a good 'un
2003 MK6 T350 90PS 2.4 TDDI MWB MHR RWD
mattt429
Postby pepperred100ps » Thu Aug 24, 2017 10:34 pm
use the oil m8, it's the ONLY way to stop rust. it's what I do
pepperred100ps
Postby mattt429 » Fri Aug 25, 2017 4:49 pm
pepperred100ps wrote:use the oil m8, it's the ONLY way to stop rust. it's what I do
i wouldn't... used engine oil can be pretty acidic (even heard of some people mixing it up with diesel - even worse :shock: )
Proper prep work, cut out rot, put new steel in and treat the rest. I did a shed load of welding last MOT and there's not even a bubble of rust since i've treated it all. If you leave rot and cover it up it spreads underneath whichever sealer/underseal you use :(
mattt429
Postby karl » Fri Aug 25, 2017 4:55 pm
Same as even me floor Wells leak oil when parked up :lol:
But I'm a diesel fitter so if oil spils in me van I leave it to find it's own way out :D I have even drilled holes in the back of the van so the oil runs under the wooden floor and when I look underneath I can see the oil coming threw places you carnt get to Happy days
karl
Tranny Lover!!!
Postby dumper » Sat Aug 26, 2017 10:45 am
At work when I was a apprentice plant fitter we had a H reg transit service van the gear oil pump was strapped on the o/s/r corner of the van and it spilled a lot of oil so underneath was covered in gear oil when the van was scraped the rest of the van was rotten but the o/s/r was like new in the new N reg van that replaced it we had a tray made up to put the oil cans in so it did not get the same amount of oil spilt in it it rotted everywhere you can't beat a bit of oil to hold back the rust
Postby andz327 » Sat Aug 26, 2017 11:34 am
Exactly back in the olden days, but there's waxoil and the like, SHUTZ is for the outside
Waxoil inside every where , fook spraying oil inside your doors etc
andz327
