I broke down a couple of months ago in a cloud of smoke and no power. I changed the EGR valve and this sorted the smoke and power issue. However, the day after the engine management light came back on showing the following codes:
P109 - EGR vacuum regulator solenoid circ
P1402 - EGR metering orifice restricted
P1103 - Mass air flow sensor in range higher than expected
I have cleared them off several times but they come back on after five minutes of driving. Gone are my days of black tape on the dash I need to rely on my van. I was thinking it might be a clogged/dirty sensor but not sure where to start. I've had a look for a loose or split hose and can't see anything obvious.
Does anyone have any ideas on what to try next before I take it down to the garage?
