central locking broken
Postby The Doug » Tue Sep 12, 2017 9:51 pm
The central locking on our 04 plate Transit has malfunctioned. We could use the key to open the drivers door but couldn't do anything with the passenger door or the side door. We took it to the local auto electricians who've been able to get the passenger to open and we can now lock the two front doors with the key, but the side door remains unlocked. They quoted £1,500(!) for the work. Any suggestions would be greatly appreciated! Thanks
The Doug
Re: central locking broken
Postby Altransit » Tue Sep 12, 2017 9:53 pm
Starting with the basics, have you checked the two C/L fuses taped to the loom under the steering column :?:
Postby The Doug » Tue Sep 12, 2017 9:58 pm
No, will have a look when we get a chance on Friday. Thanks
The Doug
Postby The Doug » Tue Sep 12, 2017 10:02 pm
Also, what do you know about dash clocks staying on constantly Altransit??
The Doug
Postby Altransit » Tue Sep 12, 2017 10:03 pm
They can be a challenge to spot, down the bottom of the column, you need to stand on your head to see them :)
No idea on the dash clocks, sorry :(
Postby The Doug » Tue Sep 12, 2017 10:08 pm
We're away in her on Friday, so will have plenty of time for standing on my head! Lol
We've heard the clocks issue is a common fault & the local auto electricians were unable to help
The Doug
Postby Altransit » Tue Sep 12, 2017 10:17 pm
The Doug wrote:We're away in her on Friday, so will have plenty of time for standing on my head! Lol
:idea: Use the search function at the top of the page, if it's a common fault, there will be lots of info on here already :)
Postby The Doug » Tue Sep 12, 2017 10:36 pm
Thanks Altransit
The Doug
Postby The Doug » Mon Oct 02, 2017 8:33 am
Will a 2013 central locking system fir my 2004 mk6? A chap is stripping a 2013 and I was thinking of using the system from his. All advice welcome. Thanks
The Doug
Postby The Doug » Mon Oct 02, 2017 2:52 pm
Any help would be appreciated guys. On fb site one guy says it wouldnt work as would need to use all the loom and ecu, another guy says it would be fine. Very confused!
The Doug
Postby Altransit » Mon Oct 02, 2017 3:33 pm
You can't use the whole system, because on the Mk7, the C/L is controlled by the BCM which you don't have on the Mk6, but I can't see why you can't use the locks themselves :?
Postby The Doug » Mon Oct 02, 2017 3:38 pm
Thanks Altransit. He's asking for £150 for the door lock and mechanism. Does that sound ok? Should I purchase? Thanks
The Doug
