Jono H wrote:Hi I'm new here so hope I've got the right place ! Yesterday I returned home in my 02 plate 2.4 transit and bumped up.on the kerb as I was parking and as I bumped back down again the engine cut out and I thought I'd accidentally stalled . When I want to restart it wouldn't start . The engine turns over plenty quick enough and it sounded as though I'd run out of fuel however there's plenty in the tank and when I cracked a couple of injectors to check there was fuel there there was loads ! Is there some sort of cut off switch I may have tripped by bumping off the kerb (unlikely I guess) or anybody got any suggestions ? Thanks
grogan197 wrote:Get a OBD scanner that works with FORScan to read any codes (costs about £10)
Camshaft or Crankshaft sensor can cause the van to cut out and not restart immediately, it will have logged a code if it was one of them and it's a cheap fix. Could be any number of other things though.
grogan197 wrote:Camshaft or Crankshaft sensor can cause the van to cut out and not restart immediately, it will have logged a code if it was one of them and it's a cheap fix. Could be any number of other things though.
APH wrote:grogan197 wrote:Camshaft or Crankshaft sensor can cause the van to cut out and not restart immediately, it will have logged a code if it was one of them and it's a cheap fix. Could be any number of other things though.
Sadly it can also be the fuel pump EDC starting to fail. they don't always fail immediately, they can start the random cutting out refusing to start for a while symptoms for months before failing completely, so can air ingress in fuel system, slackening timing chain due to tensioner starting to fail.....the list is quite extensive unfortunately.
Andy
Jono H wrote:Also any ideas where I can get a obd scanner that's compatible ? Bought an obd2 scanner but apparently it's not compatible .
Users browsing this forum: mistyv6
