andz327 wrote:Have you plugged it back on properly
andz327 wrote:When you say oil pump, where is it ? Or actually the thing your calling oil pump(oil pump is inside the sump)
nedforceone wrote:andz327 wrote:When you say oil pump, where is it ? Or actually the thing your calling oil pump(oil pump is inside the sump)
Water pump?. N
Gaz1157 wrote:nedforceone wrote:andz327 wrote:When you say oil pump, where is it ? Or actually the thing your calling oil pump(oil pump is inside the sump)
Water pump?. N
Sorry my mistake, the vacuum/servo pump on the end of the rear cam
Is that right?
andz327 wrote:Check wires closely for breaks
Yes budGaz1157 wrote:andz327 wrote:Check wires closely for breaks
Is that the wires for the sender then?
andz327 wrote:Check wires inside plastic corrugated sheath not just at plug
