Mk7 2.2dci fwd, Please help
Re: Mk7 2.2dci fwd, Please help
Postby andz327 » Fri Sep 22, 2017 9:37 pm
nedforceone wrote:
andz327 wrote:When you say oil pump, where is it ? Or actually the thing your calling oil pump(oil pump is inside the sump)
Water pump?. N
You were way off mate
andz327
Postby Gaz1157 » Fri Sep 22, 2017 9:46 pm
andz327 wrote:
Water pump?. N
Haha come to think of it there are a few water pipes in close proximity to that unit so it could be a water pump
Being honest, I’m tired and I’ve had a few bevies so I can’t be 100% sure on wether there’s water pipes going into the unit on the end of the rear cam or under/around it.
Gaz1157
Postby andz327 » Fri Sep 22, 2017 9:47 pm
Gaz1157 wrote:
andz327 wrote:Check wires inside plastic corrugated sheath not just at plug
I will, common thing to happen on these engines?
The oil leak did get pretty serious tbf and even tho I cleaned up each part as I refitted it all, there’s still some oil residue in some areas that will get cleaned when I’ve established the leak has stopped.
Just wires in general get a bit brittle on these
andz327
Postby Gaz1157 » Fri Sep 22, 2017 9:49 pm
Ok cheers
Hopefully I can sort it out first thing.
Oh the joys
Gaz1157
Postby andz327 » Fri Sep 22, 2017 10:32 pm
Gaz1157 wrote:Ok cheers
Oh the joys
Ned was way off haha Gaz yer 2nd guess was
andz327
Postby Gaz1157 » Fri Sep 22, 2017 10:45 pm
I’ve been second guessing myself on what was there
Gaz1157
Postby Gaz1157 » Sat Sep 23, 2017 3:04 pm
Cheers andz327
Found the break just below the plug (between the sender and the plug), quick fix for now till I can solder it properly tomorrow.
Gaz1157
