2007 mk 7 rwd transit
Postby rattybathead » Mon Sep 25, 2017 9:25 pm
Got a problem! gears were all working fine until cable balljoint under van ( attached to a thick steel lever) came adrift, socket head looks rusty so has obviously worn. Was wondering if I could change the balljoint on the cable or do I have to replace the cables as a unit? Cheers!
rattybathead
Re: 2007 mk 7 rwd transit
Postby v8dave » Mon Sep 25, 2017 9:34 pm
The cable are only available as a pair if you go to ford.
Don't know if anyone has single cables or has successfully changed an end.
Shift Cables
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby knobby1 » Tue Sep 26, 2017 1:21 am
Ditto v8Dave...Can't say I've seen separate cables or parts thereof for sale anywhere...I suspect a complete assy is required.
Postby rattybathead » Tue Sep 26, 2017 6:06 pm
ok. looks like new cables, then! Thanks all!
rattybathead
Postby knobby1 » Tue Sep 26, 2017 10:19 pm
rattybathead wrote:ok. looks like new cables, then! Thanks all!
Or possibly a good serviceable, unmolested set from the breakers..?? :?: :?:
