If it's fwd check fuel pipe from filter to pump , where it curls by rubber water hoses and sometimes the rubber hose actually rubs through the hard plastic fuel pipe and cause rubber pipe is sitting on the plastic pipe it blocks the the hole most of the time so seems intermittentArthurfron01 wrote:Hi all,
Have not been on here for a while,so I thought a new post was the way
Right van has been going good for a while,
The only slight problem was an oil leek on crankshaft seal,
Anyway last week the clutch started slipping and burning smell,eventually three days after warning the clutch failed completely,while waiting for RAC engine would not start,after towing to mechanic,would not start,I filled filter with diesel and started easy,since having van back,sometimes won't start till I fill filter,then starts,has cut out couple of times sometimes trouble starting,ever time I check filter its empty,any ideas,?,I was wondering could it be crank sensor oiled up off oil leek,thanks in advance
Arthurfron01 wrote:Thanks for reply,
I don't think its that
I have replaced that original pipe with a reinforced fuel pipe
Solid reinforced pipe ?? If its rubber with hose clips they have a habit of spitting at hose clip, if its clear braided plastic fuel pipe they go brittle and dont seal properlyArthurfron01 wrote:Thanks for reply,
Ma original pipeknobby1 wrote:Arthurfron01 wrote:Thanks for reply,
Certainly sounds like air getting in, have a check of the leak-back pipes on the injectors. Also check the filter head hose connections.....and the filter head itself, they've been known to crack causing the same issues...!
Arthurfron01 wrote:Andz327,
Will look into crank sensor tomorrow,
Do you think it would have this symptoms,
I just think its strange that it would not start after clutch stopped working
For fooked engine price dont you meanArthurfron01 wrote:Not keen on driving this van now ,what do these engines go for?£_
May sell complete van for engine price,
Someone with knowledge may make it good
