mk6 transit 90 t350 rwd loss of power
Postby haddzo11 » Tue Oct 03, 2017 6:51 pm
hi all,
over the past few weeks iv noticied my transit losing power espesially goign up the sl;ightest of hills. very slow on 1st gear take off and now wont go above 40 on even flat road.it now doesnt even rev past 3000 rpms! my mechanic put it on his diagnostic machine and the code came up fuel pump tensioner, whcih im not doubting but just want to make sure that the sypmtoms tally up with the possible fault.
any help will be greatly recieved
thanks
john
haddzo11
Re: mk6 transit 90 t350 rwd loss of power
Postby knobby1 » Wed Oct 04, 2017 2:44 am
Do you know exactly what the fault code was..?? Does your glow plug light flash while trying to start..??
Don't know what a fuel pump tensioner is..? :?
I'm guessing she's jumped a tooth or three on the timing chain..! But could be a number of things.
Postby haddzo11 » Sun Oct 15, 2017 4:10 pm
Hi the code was p0149 which came up fuel pump timing error. I changed the fuel pump timing solenoid which made no difference. Is. The next best place to look the timing Chain tensioner?
Thanks for your response
haddzo11
Postby knobby1 » Mon Oct 16, 2017 7:57 pm
haddzo11 wrote:Hi the code was p0149 which came up fuel pump timing error. I changed the fuel pump timing solenoid which made no difference. Is. The next best place to look the timing Chain tensioner?
Yeah....she may have jumped a tooth or three...common problem. I'd be doing the whole chain kit, including guides. Go for at least a quality kit or genuine Ford. Some of them are not great.
