brakes
brakes
Postby paul1956 » Tue Oct 10, 2017 10:55 pm
i have 1990 short wheel based transit the person i bought it from said when he got it there was no fluid in brake cylinder now unless i pump the pedals the brakes dont work am i right in assuming they need bleeding :D
paul1956
Re: brakes
Postby knobby1 » Tue Oct 10, 2017 11:57 pm
paul1956 wrote:i have 1990 short wheel based transit the person i bought it from said when he got it there was no fluid in brake cylinder now unless i pump the pedals the brakes dont work am i right in assuming they need bleeding :D
Yes..!
But I'd be giving the whole system a good looking at by someone who knows what they're looking at first, just to make sure there's nothing amiss.
Re: brakes
Postby Jim Archer » Wed Oct 11, 2017 2:01 pm
Check for leaks at the mastercylinder/servo and the rear drums. The other thing to watch for is if the pedal has gone to the floor, the mastercylinder seal gets damaged and won't hold pressure - this can get very exciting let me tell you ..... :shock:
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: brakes
Postby MinorMatt » Thu Oct 12, 2017 2:19 pm
My mk5 master cylinder started failing when I had a trailer on the back - with another transit on it...
I drove it home, then to Transitmania and back, and then to sussex and back (probably 1200 miles with it failing). Its properly scary now :lol:
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: brakes
Postby V184 » Thu Oct 12, 2017 5:15 pm
MinorMatt wrote:My mk5 master cylinder started failing when I had a trailer on the back - with another transit on it...
I would have thought it was quite dangerous as well :(
V184
Re: brakes
Postby MinorMatt » Fri Oct 13, 2017 2:43 pm
It wasn't too bad until about 60 miles from home, pulled up ok, stopped ok but pedal was spongey. After that... least said the better...
93 L GL Minibus
Re: brakes
Postby Jim Archer » Sat Oct 14, 2017 8:44 am
Mine was only when you braked gently, like when rolling up behind a queue of traffic ..... :shock:
Jim
Jim Archer
Re: brakes
Postby Altransit » Sat Oct 14, 2017 1:06 pm
Happened to me on my old Sierra, stupidly hot day, long traffic queue needing frequent stops with no chance to cool the brakes, so eventually the pedal went to the floor :shock:
I think the (old, original) fluid must have boiled because several hours later, in the cool of the night, I drove it home with no issues :)
