AndyG wrote:As above, remove the asembly with the manifold would be best.
BUT
Is it screaching
Have you had your fault codes read
Sideways play in the shaft is quite normal, as long as it doesn't touch the sides or the thing has seized.
It is quite rare for a turbo to go faulty on these engines.
Jim Archer wrote:With the EPIC system fitted to the TDs the 'glowplug' light is the engine check.
It should illuminate at ignition on, and go out immediately after starting. If it says on for 5ish seconds there is a fault logged, flashing means a actual live fault and often limp home mode.
Jim
