OBD2 Scanner
OBD2 Scanner
Postby frederic » Sat Oct 14, 2017 6:49 pm
OBD OBD2 SCANNER FAULT CODE READER READER DIAGNOSTIC TOOL
Looking for a recommendation for a suitable unit to check Transit 7/6?
Really looking to reset the engine management light on a 140 lwb 2008 Transit
fault already identified as perhaps MAP sensor (Dirty) and or crud build up on air boost slats.
frederic
Dealer recommendation "To drive it like you stole it!" perhaps will loosen crud!
frederic
Re: OBD2 Scanner
Postby karl » Sat Oct 14, 2017 7:51 pm
use the search bar :D
karl
Tranny Lover!!!
Re: OBD2 Scanner
Postby Altransit » Sat Oct 14, 2017 9:13 pm
frederic wrote:OBD OBD2 SCANNER FAULT CODE READER READER DIAGNOSTIC TOOL
frederic
I use an ELM27 OBD tool, and a laptop with free Forscan software :)
Re: OBD2 Scanner
Postby frederic » Sun Oct 15, 2017 1:39 pm
Really would like a stand alone unit not one allied to tablet/laptop.
Just want to reset the warning light as I will have cleaned the MAP sensor.
Last clean lasted for 2k+ miles of easy driving.
Will now try the other approach!
frederic
frederic
Re: OBD2 Scanner
Postby knobby1 » Mon Oct 16, 2017 7:50 pm
frederic wrote:Really would like a stand alone unit not one allied to tablet/laptop.
frederic
MS509 will do the Mk7's....it's only a reader, shows live data and can reset codes...does nowt else though.!
I have one and it works well with my 2008 140.
http://www.ebay.com.au/itm/Vehicle-Car- ... SwLApZwIpx
