2004 transit central locking
Postby 4x4 tranny » Tue Oct 17, 2017 2:05 am
Hi
Well hopefully some one can help?
When welding up the back doors in my build, removed the hole locking system on the doors, now finished have found out, mmm mybe I stuffed up, as when locking any of the other doors, they keep unlocking them selves.
So been a smart arse disconnected the hole system found van won't start. So back to drawing board.
Have search for wiring pdf but no luck ( ones I can read), is there someone who has one they could send or put me on the right track, either how to over come this or a pdf that I could check how I it be possible to fix this problem.
Thanks in advance.
4x4 tranny
4x4 tranny
Re: 2004 transit central locking
Postby loot » Tue Oct 17, 2017 2:46 pm
Each locking actuator has a switch which tells the central locking if the door is open or closed, if a door is open and you lock it by remote then it bounces them all open to show you there's a problem, this is a problem tho because when 1 lock fails they all fail and you can secure the van :roll:
The actuators can be disconnected as long as each ajar switch is in the closed position or the wires bridged.
I can't see if or how it can cause a non start tho??
How have you disconnected it all? Is there any chance of a short circuit or anything to drain the battery?
You need a tis disk for diagrams or etis 0508 for online diagrams offline.
Ids map here
loot
Postby 4x4 tranny » Tue Oct 17, 2017 11:46 pm
Thanks Loot for your input.
Never thought of thed swtiches, ill check that , guess the rear doors had one?
As for not starting, I removed the relays under thd bonnet where a humming sound came from when doors were left open , which were under the water bottle L/H side.
Yes its been a bit hit an miss, so having a wiring diagram make life easier.
Ill check switches an report.
4x4 tranny
Postby knobby1 » Wed Oct 18, 2017 3:35 am
4x4 tranny wrote:Thanks Loot for your input.
Those relays will hum for a few minutes after turning off...it's totally normal.
Postby 4x4 tranny » Sun Oct 22, 2017 12:02 pm
Ok , but when disconnecting plugs in door so doors can be locked manually, these relays just keep humming, but engine still starts, but take them out it won't start, when I sort a a wiring semastic, might be able to sort....lol
4x4 tranny
