euro 5 2.2 problems.Help.
Postby stevemknight » Wed Oct 18, 2017 10:38 pm
i dont know if any one of you can help but i am running out of ideas trying to fix my 2013 2.2 rwd euro 5 mk7 .i have owned the van for a few months and when i bought it it had problems and would hardly run. this turned out to be bad connections between the injectors and plugs(plugs replaced) this had been caused by someone metering out the loom to find a fault which was an injector i know this because with the van came a repair bill with details of a repair including checking loom and replacing injectors.the van has always sounded flat like the timing is retarded and is very bad on fuel (about 22 at 3 tons gross ) .the van does now not produce any fault codes at all.the first thing i did to try and rectify it was fit a new turbo actuator because at the time it would occasionally throw a code for actuator position .fitting a new actuator made no difference.i have since replaced the egr valve with a brand new o.e. one .fuel rail pressure sensor .removed timing cover to check cam chain and timing .substituted both the air flow meter and map sensor from another euro 5 of same year this made no difference . the van has been to ford in the last month for piston software update this made no difference other than it now dosen't stall as easy. and finally i have replaced all four injectors and coded them and this has slightly improved the power. the underlying problem seems to be that the engine sounds very quiet almost petrol like up to about 3000 rpm when it does start to develop some diesel noise but nowhere near as much as it it should. the only thing i can think to do next is to remove the gearbox and check that the tdc timing notch is exactly right . i do not know if it has had a replacement flywheel . the van is now at 100k. sorry for the very long post .
stevemknight
Re: euro 5 2.2 problems.Help.
Postby andz327 » Wed Oct 18, 2017 11:00 pm
stevemknight wrote:i dont know if any one of you can help but i am running out of ideas trying to fix my 2013 2.2 rwd euro 5 mk7 .i have owned the van for a few months and when i bought it it had problems and would hardly run. this turned out to be bad connections between the injectors and plugs(plugs replaced) this had been caused by someone metering out the loom to find a fault which was an injector i know this because with the van came a repair bill with details of a repair including checking loom and replacing injectors.the van has always sounded flat like the timing is retarded and is very bad on fuel (about 22 at 3 tons gross ) .the van does now not produce any fault codes at all.the first thing i did to try and rectify it was fit a new turbo actuator because at the time it would occasionally throw a code for actuator position .fitting a new actuator made no difference.i have since replaced the egr valve with a brand new o.e. one .fuel rail pressure sensor .removed timing cover to check cam chain and timing .substituted both the air flow meter and map sensor from another euro 5 of same year this made no difference . the van has been to ford in the last month for piston software update this made no difference other than it now dosen't stall as easy. and finally i have replaced all four injectors and coded them and this has slightly improved the power. the underlying problem seems to be that the engine sounds very quiet almost petrol like up to about 3000 rpm when it does start to develop some diesel noise but nowhere near as much as it it should. the only thing i can think to do next is to remove the gearbox and check that the tdc timing notch is exactly right . i do not know if it has had a replacement flywheel . the van is now at 100k. sorry for the very long post .
What horse power
andz327
Postby andz327 » Thu Oct 19, 2017 12:05 am
What horse power
These are quiet engines if anything like euro 4 which i have, i had a problem with a spurious prv part fitted and when it finally gave in and proper ford one was fitted the extra power and better fuel consumption was like a remap had been done
Contact "Martynx" (forum name) vantuner.co.uk, he knows stuff the ford techs don't and at very least might be able to remap for more power/economy
andz327
Postby stevemknight » Thu Oct 19, 2017 9:00 am
thanks . i have already spoke to martyn who suggested a few things to try . this van is very weird the way that when you rev it up its like a tuned two stroke the way that it bogs at the bottom end with loads of inlet noise then it takes of after a second or two.
stevemknight
Postby andz327 » Thu Oct 19, 2017 6:51 pm
stevemknight wrote:thanks . i have already spoke to martyn who suggested a few things to try . this van is very weird the way that when you rev it up its like a tuned two stroke the way that it bogs at the bottom end with loads of inlet noise then it takes of after a second or two.
Have you checked the turbo impeller wear or tightness, maybe yours is one of the ones that sufferd oil pump failure in the past and had ran turbo dry of oil, as well as other parts but maybe in repairs to engine the turbo was overlooked
andz327
Postby stevemknight » Thu Oct 19, 2017 7:17 pm
yeah had the turbo off to replace the actuator. looked and felt like brand new . i have run it with the down pipe loose and the plug out the top of the dpf to see if it made a difference but no good. it will create boost just nothing at the bottom end . one thing i have noticed is if it does not want to pull from low rpm if you release and the press the go pedal it does seem to pick up. sometimes it will not produce hardly any power for maybe ten seconds if going up a hill and all of a sudden it changes note and goes. but while it is not making power it sounds very intake noisy. thanks for the replies i really want to sort it.
stevemknight
Postby Jim Archer » Thu Oct 19, 2017 7:35 pm
VNT vanes free moving?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby stevemknight » Thu Oct 19, 2017 9:05 pm
yeah perfect . very easy and with the new actuator never produces a fault code even when you can have it not powering for over ten seconds. the bit i cannot get my head round is why it is so quiet . it has good fuel rail pressure but sounds like it dosen't . it is very quiet compared to other euro 5 transits .
stevemknight
Postby Altransit » Thu Oct 19, 2017 11:18 pm
I remember, many years ago, taking a diesel van to a specialist to sort a minor problem with the engine. It was fixed, and the mechanic said that he had "advanced the pump" to give it some more power. This it did, but the engine was much more clattery afterwards!
The point to my tale is: Is it possible that the timing on yours is retarded, sapping the power, and making the engine quieter than normal :?: Just a theory, not sure if it even relates to a modern diesel, or even if it will run like this. :roll: :mrgreen:
Postby knobby1 » Fri Oct 20, 2017 12:48 am
Altransit wrote:The point to my tale is: Is it possible that the timing on yours is retarded, sapping the power, and making the engine quieter than normal :?: Just a theory, not sure if it even relates to a modern diesel, or even if it will run like this. :roll: :mrgreen:
Not possible on a common rail machine..! :wink: Advancing the pump does nowt..! :mrgreen:
Postby bambi mk 1 » Fri Oct 20, 2017 7:51 am
Checking the timing chain wouldn't do any harm :wink:
bambi mk 1
Postby Altransit » Fri Oct 20, 2017 11:00 am
bambi mk 1 wrote:
knobby1 wrote:Not possible on a common rail machine..! :wink: Advancing the pump does nowt..! :mrgreen:
Yes, I realise that you can't alter the pump timing by turning the pump on a TDCi, but as Bambi has said, maybe the chain is out of sync :?:
Postby stevemknight » Fri Oct 20, 2017 11:05 am
had the front off the van a few weeks ago to check the cam chain tensioner and timing and it was spot on much to my disapointment .
stevemknight
Postby andz327 » Fri Oct 20, 2017 8:17 pm
He already has mucker
andz327
Postby andz327 » Fri Oct 20, 2017 8:25 pm
stevemknight wrote:had the front off the van a few weeks ago to check the cam chain tensioner and timing and it was spot on much to my disapointment .
Did you try changing tensioner , in case it's loosing pressure and knocking timing out when chain comes under load, maybe oil pressure problem
andz327
