I just bought a genuine 39k Hi Cube TD with and engine fault....
Checked timing today and reset....engine starts easily, but engine light is on and it splutters and coughs with loads of white smoke...Can here turbo whistle and seems to make boost ok
I think it could be the pump...but its the EPIC type, I did read on forum somewhere that you can fit the normal DI normally aspirated pump? is this correct? Ie any mechanical 2.5 di pump? Do I use with the normal TD 100ps injectors? any help would be great as I really need the van to help me move house.. Thanks in advance
