rogerw wrote:Simple just disconnect pump and see if speedo still works by driving it
4x4 tranny wrote:Id be more interested what /how you get on with your ASM gearbox with no computer?
Punto443 wrote:So did it need overhauled mechanically or electronically?
I believe a lot of the problems from computer derived systems come from lack of maintainence, failing to clean and calibrate and lack of knowledge. Just like failing to adjust a tappet etc, the longer it’s left the worse it will become and further out of calibration.
Servicing a modern vehicle requires updates and calibrations that can only be carried out by diagnostic equipment. And a lot of people still seem to think it’s still just a case of oil and filters. Therefore going sometimes years without correct adjustments and blaming these computers and poor design.
Run an old engine as a working motor without adjusting tappets, ignition points etc for a good few year and see how well it does?
Diagnostic equipment is both cheap and readily available now, it should be regarded as an electronic socket set to speak of.
In the same way if you approach any job without the correct tools, then how can the optimum result be achieved.
Obviously, both mechanically and computer controlled engines can both suffer component sudden failure,
Merely my take on things?
Oh, and I’m no old motor hater btw, just think people need to evolve as technology does.
Punto443 wrote:Firstly, I’d recommend and elm 327 with forscan for budget code reading.
But I’m confused?
The pump failed mechanically after 30k, but you’ve demonised the electronics, that seems a bit odd to me?
If it had been the electronics that had failed then I could see why you have an issue. It it sounds like the computer done it’s job dropping to limp to protect the engine?
But I’m confused?
