Rip out all computers and convert to full mechanical?
Postby sjmcl » Fri Oct 20, 2017 11:18 pm
I've got a 2002 Transit 350L, 2.4 DuraTorq D1 diesel, engine D2FA. Is it possible to rip out all computers and convert this to a full mechanical van?
I did this to my old 1996 Transit, because it continuously went into limp mode for no apparent reason. I replaced the EPIC fuel injection pump with a mechanical Bosh pump, and ripped out the PATS. After that it went absolutely perfect, plenty of power, good fuel economy and very reliable. It was the best thing I ever did to it.
But, can this be done to these newer Transits as well? Or is the computer too embedded in the whole van?
sjmcl
Re: Rip out all computers and convert to full mechanical?
Postby karl » Sat Oct 21, 2017 7:58 pm
anything is possible but
what engine do you want to put in it :!:
karl
Tranny Lover!!!
Postby Punto443 » Sat Oct 21, 2017 9:00 pm
^think he just wants a manual pump conversion.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby karl » Sat Oct 21, 2017 9:10 pm
Punto443 wrote:^think he just wants a manual pump conversion.
well he will be waiting a long long long long time :lol:
karl
Tranny Lover!!!
Postby ned » Sat Oct 21, 2017 9:11 pm
Like Karl says anything is possible but it'll be hard work, new loom, manual pump and throttle cable ect, the speedo might be a problem though. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby sjmcl » Sat Oct 21, 2017 10:52 pm
With my 1996 Transit I simply disconnected the electrical connections to the fuel pump but left the loom in place.
I replaced the EPIC fuel pump with a Bosh pump and installed a mechanical throttle pedal and cable. It wasn't that hard, and certainly worth the effort.
So the question I have with this Transit boils down to this : does the computer control anything else besides the fuel pump and ASM gearbox? I couldn't care less about the PATS as I have no need for it.
sjmcl
Postby karl » Sat Oct 21, 2017 10:57 pm
the speedo
karl
Tranny Lover!!!
Postby sjmcl » Sat Oct 21, 2017 11:11 pm
karl wrote:the speedo
Even a fully analog speedo?
sjmcl
Postby bigjohnthomas » Sat Oct 21, 2017 11:24 pm
By anal,og do you mean by means of hands or a pointer rather than a digital display?
bigjohnthomas
Postby sjmcl » Sun Oct 22, 2017 1:32 am
bigjohnthomas wrote:By anal,og do you mean by means of hands or a pointer rather than a digital display?
Yes, old fashioned display with dials and mechanical odometer.
sjmcl
Postby ned » Sun Oct 22, 2017 4:57 am
Yep analogue speedo still runs through the pcm, there is no cable driven speedo . N
ned
Postby ake » Sun Oct 22, 2017 8:53 am
My question is why?
Does the van run ok as it is?
If so leave it alone, the rust will kill it before the engine dies!
Postby bigjohnthomas » Sun Oct 22, 2017 8:59 am
Computers are the enemy
One day they will enslave you humans 8)
And if converting a digital van to analog will stop them then do it
bigjohnthomas
Postby Punto443 » Sun Oct 22, 2017 10:29 am
Apparently ford supplied mk6 vans to some third world countries with a manual pump?
Someone was looking into it, but then it all went quiet.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby rogerw » Sun Oct 22, 2017 12:32 pm
Simple just disconnect pump and see if speedo still works by driving it :roll:
2003, petrol
rogerw
cron
