Central locking fail after CC & Locking at speed activation
Postby fletchyfletch » Sat Nov 04, 2017 11:45 pm
I had a few things activated at a tuning shop yesterday, including locking at speed and cruise control. Everything is working as normal except for the locking at speed, which worked once, and central locking.
When I press the CL button on the fob or activate it through the door locks I can hear a buzzing from the rear locking motors and then a beep to signify that the van is still unlocked. No sounds from the front doors.
I got home and checked for errors on Forscan.. nothing. I deactivated locking at speed and still I have the same issue. Any ideas?
Ford Transit Mk7 FWD SWB 2011 2.2 litre
fletchyfletch
Re: Central locking fail after CC & Locking at speed activat
Postby andz327 » Sun Nov 05, 2017 12:17 am
fletchyfletch wrote:I had a few things activated at a tuning shop yesterday, including locking at speed and cruise control. Everything is working as normal except for the locking at speed, which worked once, and central locking.
Check wiring loom to rear doors especially where it goes through the tubes
andz327
Postby Altransit » Sun Nov 05, 2017 12:51 am
It's probably a configuration error :idea:
Mine did this when I had a new BCM fitted, the new configuration wasn't right and all of the doors weren't locking, causing the horn to beep.
Re-configuring the locking sequence cured the problem :)
Postby fletchyfletch » Sun Nov 05, 2017 12:57 am
andz327 wrote:Check wiring loom to rear doors especially where it goes through the tubes
The thing is that I still hear the motors trying to work on the rear doors but nothing engages. Also, it was working before the CC activation.
fletchyfletch
Postby fletchyfletch » Sun Nov 05, 2017 12:59 am
Altransit wrote:It's probably a configuration error :idea:
I suspected as much but i have about 30 minutes experience on Forscan. I've turned off the auto locking at speed without any change and I have no idea how to reconfigure the locking sequence. Do you know how?
fletchyfletch
Postby Altransit » Sun Nov 05, 2017 1:06 am
fletchyfletch wrote: Do you know how?
I'm sorry, but it was being done for me by MartynX (vantuner), he was using genuine Ford IDS to do the software thing because the BCM config had to be copied from the old one to the new one.
I seemed to lose my hill launch assist during the config, so these things don't always go smoothly :P
Postby fletchyfletch » Sun Nov 05, 2017 1:12 am
Alas, I live too far away from Martyn and can’t afford the few days without working van so I’m left sorting out he niggles by myself
fletchyfletch
Postby andz327 » Sun Nov 05, 2017 1:16 am
andz327
Postby martynx » Sun Nov 05, 2017 10:22 am
Maybe fit the old BCM temporarily to see if the central locking works again? That may rule out a lock or wiring issue. & I wonder if the hill start would work if a door is open (or is falsely being reported as open).
Sent from my SM-G930F using Tapatalk
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby Altransit » Sun Nov 05, 2017 11:28 am
martynx wrote:Maybe fit the old BCM temporarily to see if the central locking works again? That may rule out a lock or wiring issue. & I wonder if the hill start would work if a door is open (or is falsely being reported as open).
It was me that had the new BCM Martyn, the OP has had a locking problem since activating auto locking on his existing BCM.
You might remember that mine did this, when you fitted the upgraded BCM and you had to do something with engineering mode to make the locks work properly :)
Postby martynx » Sun Nov 05, 2017 11:42 am
Hi Al:) on post 6 it's mentioned about old to new ? i recall a BCM swap to C job but it was some weeks ago now , am I going nuts !!??
martynx
I do recal yours though ;)
martynx
Postby Altransit » Sun Nov 05, 2017 11:55 am
martynx wrote:Hi Al:) on post 6 it's mentioned about old to new ? i recall a BCM swap to C job but it was some weeks ago now , am I going nuts !!??
Probably me that's going nuts, I've just noticed that the OP says in his sig that he has a 2004 Mk7!, so I have no idea now :!: :?
Postby martynx » Sun Nov 05, 2017 12:38 pm
And post #1 says yesterday! I've not done one for weeks , lol
martynx
Postby andz327 » Sun Nov 05, 2017 1:03 pm
Op never mentioned Martynx just a tuning shop, it was ALtransit that mentioned the God and dude said he stayed to many miles from EL VANTUNER. , was wondering aboot the 2004 mk7
andz327
