FWD and RWD MK7 height difference
Re: FWD and RWD MK7 height difference
Postby andz327 » Fri Nov 10, 2017 12:43 am
birdie wrote:
tb2000 wrote:Ok thanks for the reply. I'll be looking for a FWD hightop at some point then! Luckily I don't really need towing capability (highly unlikely to ever need it), even so I think the FWD T350 can tow 2 ton anyhow. I would expect FWD T350's (or anything over T300) are harder to find than RWD versions!
Out of interest do you know what the height difference is? Is it just the step difference (which appears to be about 4 or 5 inches)?
Cheers :)
My t350 fwd has a towing weight of 2800kgs
Train weight 6300kg? On a fwd ?
andz327
Postby bigjohnthomas » Fri Nov 10, 2017 12:48 am
A fwd can carry more weight than a rwd too :P
Somink like 175 tonnes more
Might be kg though :?
I'll have a look at the arsewash 3000 when its convenient and safe to do so
bigjohnthomas
Postby knobby1 » Fri Nov 10, 2017 2:33 am
bigjohnthomas wrote:Rwds are for dirty builder and allotment types
Thank you..! I'm no builder nor an allotment type....but I am dirty :wink: :lol: :mrgreen:
Postby Altransit » Fri Nov 10, 2017 3:07 pm
It doesn't work like that, my 280 has a train weight of 3500kg, GVW of 2800kg, but a towing max of 1550kg. Obviously, you can't tow 1550kg if it's already loaded to 2800kg :)
Postby andz327 » Fri Nov 10, 2017 3:18 pm
Yeah i know mate, thats what i was getting at
andz327
Postby tb2000 » Fri Nov 10, 2017 6:07 pm
Sounds similar to mine. Odd thing is is that my old 85T280 (low roof SWB) had a (braked) towing weight of 1550kg if I remember correctly, whereas my 140T280 (med roof MWB) is 1450kg. I thought it would've been a bit higher considering the more powerful engine! I suppose they had to knock 100kg off to take the extra weight of the longer higher van.
I've seen some T300 vans with 2500kg towing capability (probably RWD though) but then i've also seen them with only 1000kg capability (probably FWD), on the id plate anyway.
Although i'm unlikely to need it, 2800kg sounds good if I found a T350 fwd with that ability!
tb2000
Postby andz327 » Fri Nov 10, 2017 6:23 pm
tb2000 wrote:
Altransit wrote:
andz327 wrote:[quote="birdie"]
Although i'm unlikely to need it, 2800kg sounds good if I found a T350 fwd with that ability![/quote]Its lower because actual van is heavier keeping train weight still 3500kg which will keep you under tacho threshold if using for hire and reward/ business use
andz327
Postby bigjohnthomas » Fri Nov 10, 2017 7:20 pm
What's that then 2 tonne trailer if I were a dirty builder ?
Or just dirty like lord knobrot :lol:
bigjohnthomas
Postby bigjohnthomas » Fri Nov 10, 2017 7:23 pm
The arsewash 3000 btw
Its a Lwb hi roof fwd
bigjohnthomas
Postby andz327 » Fri Nov 10, 2017 10:25 pm
bigjohnthomas wrote:The arsewash 3000 btw
Yeah or even a bit more if the arsewash isn't loaded to yer max 3500kg
andz327
Postby ned » Fri Nov 10, 2017 10:31 pm
bigjohnthomas wrote:What's that then 2 tonne trailer if I were a dirty builder ?
What's the fag6 bit all about? What does it mean?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Sat Nov 11, 2017 1:07 am
Was thinking that maself mate hahaha, must be something to do with arse washing
andz327
Postby bigjohnthomas » Sat Nov 11, 2017 7:54 am
It was originally a bog washer for home serve so
Could be to do with homosexual activity?
bigjohnthomas
Postby bambi mk 1 » Sat Nov 11, 2017 9:21 am
Its only on fwd ,fook all good :wink: :mrgreen:
bambi mk 1
Postby bigjohnthomas » Sun Nov 12, 2017 1:04 am
dont mock the fwd
for you will summon up the queer fella
https://www.youtube.com/watch?v=mb3qKcY3P-Q
bigjohnthomas
