will a 2.4 motor run with only 3 glow plugs
Postby Mike Saunders » Fri Nov 10, 2017 12:12 am
Hi all
Have a Ford Transit 350L Td Xhigh 2001 Mk6
Will it go with only 3 working glow plugs
Van will start then stop (just die) and glow plug light flashes on off
Have just put new timing chain in motor and injectors and diesel pump in motor to go from 90 to 120ps
hoping someone can help thanks lots Mike
Mike Saunders
Re: will a 2.4 motor run with only 3 glow plugs
Postby bambi mk 1 » Fri Nov 10, 2017 12:20 am
What year did the donor pump come from :?: Is the crank sensor connected :?:
bambi mk 1
Postby Mike Saunders » Fri Nov 10, 2017 12:37 am
bambi mk 1 wrote:What year did the donor pump come from :?: Is the crank sensor connected :?:
pump is from van got another motor and put pump and injectors in it. and yes crank sensor is connected
Mike Saunders
Postby Jim Archer » Fri Nov 10, 2017 7:09 am
Is the ECU from a 120?
You will need the codes read - using IDS preferably.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby bambi mk 1 » Fri Nov 10, 2017 10:00 am
Lets run this by again ,you have changed complete engine pump and injectors from another van :?:
bambi mk 1
Postby andz327 » Fri Nov 10, 2017 11:35 am
Different engine, same pump and injectors
andz327
Postby Mike Saunders » Sat Nov 11, 2017 1:13 am
Just motor
ecu and injectors pump are from van
so should go just starts and then dies
Yes waiting on a guy to do scan so heres hoping
Mike Saunders
Postby Mike Saunders » Sat Nov 11, 2017 1:16 am
Jim Archer wrote:Is the ECU from a 120?
Jim
thanks Jim
Mike Saunders
Postby bambi mk 1 » Sat Nov 11, 2017 9:14 am
Did you use the engine loom from the original engine :?:What year is the engine from :?: As the teeth said to the dentist ,fill us in :wink:
bambi mk 1
Postby ned » Sat Nov 11, 2017 9:30 am
bambi mk 1 wrote:Did you use the engine loom from the original engine :?:What year is the engine from :?: As the teeth said to the dentist ,fill us in :wink:
Reading the original post it sounds like its not had an engine swap just the pump and injectors :wink: No mention of the pcm being swapped as well.
Answer to original question is yes. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Jim Archer » Sat Nov 11, 2017 9:51 am
Does sound like crank sensor, 'specially if it runs for about 4-5secs then just shuts off.
You have deffo got the correct connector ..... erm ...... connected? - the speedo one looks the same. And the lead hasn't got damaged when fitting up the new motor?
Jim
Jim Archer
Postby Mike Saunders » Tue Dec 12, 2017 8:57 am
Hi All
Just got round to looking at Van and was speedo and crank sensor round wrong way
My stuff up but all go now and runs AWESOME
Feel like a dick lol but did get told they did not reach each other so could not be done.
But anyway thanks to all AWESOME FORUM and will be back lol now on to getting the central locking working
Thanks Lots Mike :D
Mike Saunders
