broken/burnt out wire
Postby caspersteve » Sun Nov 12, 2017 4:50 pm
hi every body hope your all well.
im just wondering if any body knows what the small wire coming from the positive battery terminal under the bonnet is.
its the terminal under the red cover next to the under bonnet fuse box there is a main battery cable attached to the flat post used for jump lead and a much smaller but still quite heavy gauge wire coming from it as well which disappears into the under bonnet fuse box, its this wire that is broken... it looks to have got hot due to corrosion maybe and has now snapped. I haven't noticed any starting issues or any other electrical faults so im wondering what exactly it is powering??
any help would be greatly appreciated
kind regards all
casper
caspersteve
Re: broken/burnt out wire
Postby ned » Sun Nov 12, 2017 5:05 pm
T'is the glow plug fuse wire, don't worry about it most transits have that wire burnt out, mines been like that for 3 years without starting problems :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby caspersteve » Sun Nov 12, 2017 6:47 pm
ah thanks Nedforceone
i did wonder if it was gonna be something like that but wasnt sure
:D :D :D
caspersteve
