Transit mk 7 Dash cluster
Postby H3ggf1 » Sun Nov 12, 2017 11:25 pm
hi guys I’ve got a 56 plate transit and I have problems with speedo cluster on the dash
Once I get to abt 60-70 mph a couple of lights come on and then my speedo needle drops to zero then the digital display disappears from numbers to lines
I have a video of it happening any advice or help would be really appreciated
H3ggf1
Re: Transit mk 7 Dash cluster
Postby loot » Sun Nov 12, 2017 11:29 pm
It's either a power problem so if you have 2 batteries get them both tested and also check the cables for corrosion etc.
Or the speedo is fudged.
Ids map here
loot
