My ECU has been tested and found not repairable, been told the van must go to ford for new one and programming.
If i get a s/h engine and its ECU and fit both will that work or does the ECU need to be programmed to the van, and the engine.
Altransit wrote:You need to get an ECU with similar numbers to yours, and then ask someone with Ford IDS (Vantuner for example!) to clone it to your original ECU
karl wrote:just get an ecu and get someone to-do the programming mate no need to change the engine
what year is the van ?
and were are you in this big world
Floatmender wrote:Altransit wrote:You need to get an ECU with similar numbers to yours, and then ask someone with Ford IDS (Vantuner for example!) to clone it to your original ECU
Thanks for suggestion but If my ECU is beyond repair how can it be cloned.
Floatmender wrote:karl wrote:just get an ecu and get someone to-do the programming mate no need to change the engine
Thanks for reply
its an 07
In Sussex
