Oldvandriver wrote:Brains_transit
I pulled out the soapdish affair on the passenger side of the dashboard shelf and found some relays and fuses, do you mean in here for remote unit ? according to ETIS this van is supposed to have remote door entry so still looking.... is the remote unit seperately fused from the door keyhole operating bit ?
If u don't have a keyhole in the passenger side u have remote central locking... The box they are talking about is behind/under the glove box with a big blue and green plug that plugs into it...Oldvandriver wrote:. Does anybody know how I can tell if I have an original programmed for van key or a clone ? I bought a remote fob to save wear and tear on the lock and key (I only have one key !). and the thing does not work. So, I assume that a cloned key will not allow me to programme a fob ? Another thing, all the instructions say when you go through the on-off key sequence that I should be able to hear the locks cycling, I cannot hear this. sounds a bit unlikely anyway so what to do next ? are these chinese fobs any good anyway ?
