V8_Bodge wrote:Okay, full loom transplant it is.
So I'll need the loom with the transponder ring, the key shown below and the ECU to match?
ned wrote:Isn't the pats on the fuel pump on the mk6 tddi. N
Jim Archer wrote:Pretty sure it's onboard with the ECU.
Jim
Altransit wrote:Just raising a query here ........................
Will there be an issue with the Mk6 gearbox not having a speedo drive for the Mk5 speedo, or is that only the later ones
Brains_transit wrote:Altransit wrote:Just raising a query here ........................
You can maybe use the mk6 speedo as they look similar in size or make it fit like the mk7 dash in the mk6 or put the whole dashboard in too.
