gptfytsm wrote:It has a LED in the headlining, it flashes slowly on and off, and then when ignition is turned on, goes solid for ~2 seconds then turns off
There is a fusible link built into 1 of the leads going to the battery (cannot remember if +or - ) might be worth checking with a multimeterAltransit wrote:gptfytsm wrote:It has a LED in the headlining, it flashes slowly on and off, and then when ignition is turned on, goes solid for ~2 seconds then turns off
That's working exactly as it should, so that can't be your issue here
Peter arries wrote:There is a fusible link built into 1 of the leads going to the battery (cannot remember if +or - ) might be worth checking with a multimeter
Sent from my SM-G930F using Tapatalk
Users browsing this forum: SonofHendrik
