diff ratio mk6 jumbo
Postby kennyb11 » Fri Dec 01, 2017 10:20 pm
hi folks hope your well ,I have a 2002 mk6 jumbo 2.4 di rwd .I'm changing the rear axle due to leaking diff seal front and back and bad corrosion.The van I'm getting the axle from is a mk6 mwb same year as mine.Will the diff ratios be the same? I have tried to find the ratio on mine to no avail ,The vin number of my van is wfolxxgbfl1e20916 .I don't know the vin number of the donor van yet but at sixty notes it was too cheap to pass up.can I expect any problems after ive fitted this or are both axels the same? thanks in advance for any advice
kennyb11
Re: diff ratio mk6 jumbo
Postby Altransit » Fri Dec 01, 2017 11:44 pm
Your diff is a 5.13, which is a towing/fullyloaded/low speed ratio.
Postby kennyb11 » Fri Dec 01, 2017 11:59 pm
Thank you for that ,how would I find the ratio of the mwb axle?
kennyb11
Postby Altransit » Sat Dec 02, 2017 12:03 am
1/ From the reg/VIN number of the van it came out of
2/ Plate on diff casing
3/ counting the turns of the half shaft, relative to the propshaft
Postby kennyb11 » Sat Dec 02, 2017 12:08 am
thanks for the quick reply altransit I appreciate it,i thought all diffs were the same but apparently not,i should stick to gas fitting give me a shout if your boiler breaks down
kennyb11
Postby Altransit » Sat Dec 02, 2017 12:21 am
kennyb11 wrote:thanks for the quick reply altransit I appreciate it,i thought all diffs were the same but apparently not,i should stick to gas fitting give me a shout if your boiler breaks down
:lol: viewtopic.php?f=23&t=183504 Didn't see you chipping in :mrgreen: :P :lol:
Only joking buddy :wink: :D 8)
Postby kennyb11 » Sat Dec 02, 2017 10:01 pm
so is 5.13 the highest number on these diffs ? if so worst case scenario is I end up with the same ratio .and if its lower on the donor van this would then lower the revs at speed ,is that right?
kennyb11
Postby twin wheel camper » Sat Dec 02, 2017 10:21 pm
Think there is a 5.83 or there about,s but not common.
twin wheel camper
Postby kennyb11 » Sun Dec 03, 2017 3:16 pm
hi folks ,picked up donor axle today and its in pretty good nick but no plate on it and no reg on the van .I did get the vin number which is wfolxxbdfl3L89281 if someone could tell me the ratio of this diff I would be much obliged, thanks in advance
kennyb11
Postby bambi mk 1 » Sun Dec 03, 2017 4:13 pm
Take off the diff cover and the ratio will be etched on the crown wheel .You may have to rotate it .Change the oil and wash it out when you are in there :wink:
bambi mk 1
Postby Altransit » Sun Dec 03, 2017 11:13 pm
kennyb11 wrote:hi folks ,picked up donor axle today and its in pretty good nick but no plate on it and no reg on the van .I did get the vin number which is wfolxxbdfl3L89281 if someone could tell me the ratio of this diff I would be much obliged, thanks in advance
Build Date: 14.05.2003
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
BTW, when you write Ford VIN's, the 3rd character is a zero, not an Oh :mrgreen: :)
Postby kennyb11 » Mon Dec 04, 2017 9:31 pm
thanks for that ,same diff as the one coming off ill give it a good clean up ,new oil and swap everything over at the weekend. new studs as well save the wheel falling off again.
kennyb11
