When you changed your fuel filter did you do as Ned said and check old filter for small bits of metal in it ?? Tdci mk6's are a bit of a nightmare mate unless it's been very well looked after and finding a can of easy (fook ma engine up) start ,this doesn't look as though it hasPikeonhisbike wrote:Hello
Basically I have a ford tourneo 2004 2.0 TDCI 9seater van.. I brought the van running but the next day I went to start it and it didn't want to know, I soon found a can of easy start hidden in the van, after takeing the Airbox off I found it was full of easy start it poured out like a jug of water.... I replaced the crank sensor and fuel filter and the van started up lovely, i even went for a day out with the wife and kids in it.. It was running great for about 2 days and then this happend.... I was driving along at about 60mph and she randomly cut off, so I put the clutch in and released it and still nothing so I put the clutch in again and noticed the key wasn't in position properly so I turned the key forward more and the engine started again and I carried on my way..when I got home I turned it off and left it 5 mins and started it again, this time it took 3secs turning the key for it to start, so I repeated this a couple of times, each time it took longer to start, till eventually it didn't start and then the battery got flat untill the starter motor was just ticking....... So I charged the battery overnight and got new glow plugs fitted and a new airfilter but still she is just cranking but not running.... Can anyone help me please... Cheers pike
Pikeonhisbike wrote:No I haven't opened the filter up yet it's still sat outside my backdoor....that's if my wife hasn't got to it yet... What does metal bits in the filter mean? ..Cheers
Brains_transit wrote:Pikeonhisbike wrote:No I haven't opened the filter up yet it's still sat outside my backdoor....that's if my wife hasn't got to it yet... What does metal bits in the filter mean? ..Cheers
The metal bits come from a worn fuel pump
ned wrote:If you put a clean glass under your fuel filter and drain some off from the water drain on the bottom, it doesn't have to be loads just about 2 - 3 cm in the glass, you will see if any swarf (metal filing) are in the fuel, abit like glitter in water.
If no swarf present perform a leak off test on the injectors to see the health of them.
When you van attempted to kill you (which they do, evil b*stards) did the coil light flash?.
When you are trying to start the van does the coil light flash, a tdci will very rarely start with that evil light flashing and if it does you get a horrible diesel knock and no power. N
ned wrote:Orange sludge That'll be rust from the water in the filter, it wont have done the pump and injectors much good.
I still think you have injector problems, do a leak back test to see.
Yes its bloody scary the first time the van shuts down doing 60+ on the motorway or over taking, I used to drop the clutch and restart the van on the key rather then bump starting it. N
How much water came out ? Refill filter and see if it goesPikeonhisbike wrote:I wouldn't say it started on easy start, it just made a loud clackity noise for a few seconds then shut off
