Epic trouble
Epic trouble
Postby Mac1984 » Sat Dec 09, 2017 8:02 pm
Hi all,
First of all apologies if this has been covered before, i am in a desperate situation.
My 98 TD has the following symptoms:
Red engine warning light came on.
Loss of power, I can get moving all right but barely reach 60 on the flat, the slightest climb-
I will lose speed drastically.
Engine keeps running for maybe 10 seconds after I have turned the key.
I will have to go to mot next week, so that's why I am panicking a bit.
I have seen the question been raised as I have looked through the forum if the engine keeps running
When switched off, but I did not find an answer to it .
Thanks for any information towards this.
Cheers
1996 2.5TD Bosch Mod, Bio degradable Body from factory but outlived its manufacturing plant.
Mac1984
Re: Epic trouble
Postby Altransit » Sat Dec 09, 2017 8:49 pm
Short fix; Stall engine as you turn off the key :)
Permanent fix; Fit new ESOS (electronic switch off solenoid) to the pump 8)
Re: Epic trouble
Postby Mac1984 » Sun Dec 10, 2017 3:51 pm
Tried that this morning, and I flew along the motorway.
Thanks for the advice, at least it didn't feel like a continental drift anymore,
However the delay in shutoff still exists .
Is there a DIY/ temporary solution that I can do, just to get it through the test? I guess it will take a while to get the parts required?
Thank you so much
Mac1984
Re: Epic trouble
Postby V184 » Sun Dec 10, 2017 5:23 pm
tell the test station its got a special immboliser that allows the engine to run for 10 seconds :wink:
V184
Re: Epic trouble
Postby Jim Archer » Sun Dec 10, 2017 9:06 pm
As long as they don't claim it is a 'turbo timer' and bounce it for the MOT.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: Epic trouble
Postby Mac1984 » Wed Dec 13, 2017 7:55 pm
Thank goodness she passed. I actually got it through as turbotimer.
They had a laugh like, what kind of crazy guy had a performance car thing in a transit, but I got my disc.
Thankfully it switched off every time the same way.
Cheers
Mac1984
Re: Epic trouble
Postby MinorMatt » Mon Dec 18, 2017 12:33 pm
What Altransit said. Stall it until you fit a new ESOS plunger. How too in the how too section
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
