Rounded starter motor bolt!!
Postby Pikeonhisbike » Mon Dec 11, 2017 8:56 pm
Ford transit tourneo 2004 2.0 TDCI
Right.... So iv gone and brought a new starter motor but when I went to take the old starter off the van and the top 13mm bolt is rounded and now aswell as it being a pain in the butt to get to, I can't get a grip on it.. Doesn anyone have any suggestions on how I can remove it? Cheers pike
Pikeonhisbike
Re: Rounded starter motor bolt!!
Postby dodgy01 » Mon Dec 11, 2017 9:08 pm
1/2 inch socket and a hammer
dodgy01
Postby ned » Mon Dec 11, 2017 9:08 pm
Have you tried knocking a 12mm socket on, if you take both intake manifolds off you should be able to get to it better. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Mon Dec 11, 2017 9:10 pm
dodgy01 wrote:1/2 inch socket and a hammer
Great minds think alike :wink: N
ned
Postby twin wheel camper » Mon Dec 11, 2017 9:16 pm
Make sure your using a 6 point socket :!:
Failing that get/borrow them special sockets that cut into the bolt head the harder you turn to loosen, they’ve never failed to remove a bolt for me yet my set is made by Irwin and cost less than £20, the best money I’ve spent in a long time on tools.
twin wheel camper
Postby Pikeonhisbike » Mon Dec 11, 2017 9:34 pm
ned wrote:Have you tried knocking a 12mm socket on, if you take both intake manifolds off you should be able to get to it better. N
Iv tried a 12mm socket but it won't go on and there's no way I can get a hammer in there to persuade it :?
Pikeonhisbike
Postby ned » Mon Dec 11, 2017 9:43 pm
The other option is as twin wheel camper said use a stud extractor socket :D N
ned
Postby dodgy01 » Mon Dec 11, 2017 9:54 pm
i said 1/2 inch not 12mm
dodgy01
Postby Pikeonhisbike » Mon Dec 11, 2017 10:11 pm
Okay, I will try 1/2 inch... Is it true that if you somehow stretch the rubber off a burst balloon over a rounded bolt you can gain grip? Have any of you heard of this before? Pike
Pikeonhisbike
Postby Punto443 » Mon Dec 11, 2017 10:30 pm
Cut the head off, or drill the head off.
Pull the starter off, then blow torch the bolt and unscrew it with mole grips
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby bambi mk 1 » Mon Dec 11, 2017 11:17 pm
Punto443 wrote:Cut the head off, or drill the head off.
Pull the starter off,pull the battery out then blow torch the fooker and unscrew the cap of the Famous Grouse and drop the lot
Mk 6 tdci best thing to do with it :wink:
bambi mk 1
Postby Pikeonhisbike » Mon Dec 11, 2017 11:54 pm
That's not very nice... Even though my van isn't working properly at the moment and hasn't been working properly due to various reasons since iv had it, I love my van, it's great and has character and I look forward to enjoying it when it's working
Pikeonhisbike
Postby knobby1 » Tue Dec 12, 2017 12:27 am
Pikeonhisbike wrote:I love my van, it's great and has character and I look forward to enjoying it when it's working
LOL...!! Mk6 & TDCi don't really go together very well. :wink: Ask Ned.. :wink: :lol:
"When it's working" is the in-operative phrase here methinks..! :wink: :wink: :mrgreen:
Postby dumper » Tue Dec 12, 2017 1:05 am
Have you got enough room to mig weld a bigger nut over the rounded bolt the heat will also help free the bolt off
Or in the past I have used a die grinder and high speed metal bur if you can’t get a disc grinder in
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Brains_transit » Tue Dec 12, 2017 4:11 am
Take the rad out and then you can get at it
Brains_transit
