Glow Plug Warning light MK6 2004 2.4DT van
Postby Ozzy1136 » Thu Jan 04, 2018 4:19 pm
Hey everyone,
The Glow Plug light is flashing on my van all the time, which I suspect has caused the ECU to put it into limp mode.
I have isolated the glow plugs by removing the relay under the bonnet but nothing has changed. I understand it might not be the GP's that are causing the light to flash?
Could anyone suggest any other theories to get the light to stop (other thasn taking the bulb out) cos I'd like it to drive properly?
thanks loads
Ozzy :?:
Ozzy1136
Re: Glow Plug Warning light MK6 2004 2.4DT van
Postby martynx » Sat Jan 06, 2018 2:46 pm
The lamp doubles up as a "serious" fault indicator on MK6's, a plug in & (diagnostic test) should point you in the right direction :)
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby Altransit » Sat Jan 06, 2018 4:57 pm
