Anyone know how to remove the intercooler on a mk6 2.0 diesel transit.
cant find the bolts that hold the cross member in place.
stagg65 wrote:Anyone know how to remove the intercooler on a mk6 2.0 diesel transit.
ned wrote:That parts pic shows 2 different boost pipes from the turbo to intercooler, what is the black resonators job in the boost pipe up near the turbo?. N
wojciech wrote:stagg65 wrote:Anyone know how to remove the intercooler on a mk6 2.0 diesel transit.
The four bolts that hold IC are between IC and engine cooler. They hold IC to "support radiator" (nr 4 on first picture).
Support radiator is hold tu body by two screws nr 14 on this picture.
So: first protect engine cooler against dropping when support radiator will be loose. On picture are two red arrows - in engine cooler bolts are small transverse holes, put into this holes stick (for example nail or small screwdriver). Now radiator will be safety hang during support radiator disassembly.
Now you can unscrew support radiator and safety lower it, and than unecrew IC.
I really don't understand, why screws holding IC are access from engine cooler side...
