intercooler removal
intercooler removal
Postby stagg65 » Sun Jan 07, 2018 5:54 pm
Anyone know how to remove the intercooler on a mk6 2.0 diesel transit.
cant find the bolts that hold the cross member in place.
stagg65
Re: intercooler removal
Postby paul2012 » Sun Jan 07, 2018 6:50 pm
4 bolts secures radiator support in place- 2 at each end. Intercooler is bolted to the bottom of that support.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby wojciech » Sun Jan 07, 2018 9:21 pm
stagg65 wrote:Anyone know how to remove the intercooler on a mk6 2.0 diesel transit.
The four bolts that hold IC are between IC and engine cooler. They hold IC to "support radiator" (nr 4 on first picture).
Support radiator is hold tu body by two screws nr 14 on this picture.
So: first protect engine cooler against dropping when support radiator will be loose. On picture are two red arrows - in engine cooler bolts are small transverse holes, put into this holes stick (for example nail or small screwdriver). Now radiator will be safety hang during support radiator disassembly.
Now you can unscrew support radiator and safety lower it, and than unecrew IC.
I really don't understand, why :evil: screws holding IC are access from engine cooler side...
wojciech
Postby ned » Sun Jan 07, 2018 9:39 pm
That parts pic shows 2 different boost pipes from the turbo to intercooler, what is the black resonators job in the boost pipe up near the turbo?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby wojciech » Sun Jan 07, 2018 9:53 pm
ned wrote:That parts pic shows 2 different boost pipes from the turbo to intercooler, what is the black resonators job in the boost pipe up near the turbo?. N
Pipe nr 2 is for 2,4l engines, pipe nr 8 with plastic part is for 2,0l engines...
wojciech
Postby wojciech » Sun Jan 07, 2018 10:14 pm
What is the black resonators job - I don't know...
Everywhere they call it "breathers" https://www.google.pl/search?q=ford+667 ... AG#imgrc=_
wojciech
Postby stagg65 » Mon Jan 08, 2018 5:40 pm
Thats brilliant, thanks very much.
stagg65
