125hp TDDI head
125hp TDDI head
Postby headbolt » Sun Jan 07, 2018 10:08 pm
does anyone know if the heads on the 125hp TDDI engine are any different form other models thanks as I am in need of a new head for 125hp and just want to be sure before I buy one thanks
MK6 125 BHP 330 rwd 2.4
headbolt
Re: 125hp TDDI head
Postby andz327 » Sun Jan 07, 2018 10:12 pm
Is there such a beast ????
andz327
Re: 125hp TDDI head
Postby Punto443 » Sun Jan 07, 2018 10:44 pm
Rwd 125 is a tddi.
I think only the tdci head differs and all tddi heads are the same if the same engine capacity.
But Karl will know.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: 125hp TDDI head
Postby bambi mk 1 » Sun Jan 07, 2018 10:45 pm
Any rwd 2.4 tddi head will fit ,but check if glow plugs are out if buying used as you will most likely need them with a 125 :)
bambi mk 1
Re: 125hp TDDI head
Postby knobby1 » Sun Jan 07, 2018 10:49 pm
bambi mk 1 wrote:Any rwd 2.4 tddi head will fit ,but check if glow plugs are out if buying used as you will most likely need them with a 125 :)
If they're out...just buy a new set of plugs...too easy..!
Re: 125hp TDDI head
Postby bambi mk 1 » Sun Jan 07, 2018 11:04 pm
And if they are not get the seller to remove them :wink:
bambi mk 1
Re: 125hp TDDI head
Postby headbolt » Sun Jan 07, 2018 11:16 pm
thanks guys good to know and yes definetly getting new glow plugs before fitting on van
headbolt
Re: 125hp TDDI head
Postby andz327 » Mon Jan 08, 2018 1:21 am
Easy to get them oot with it off, plenty room to drill, tap , screw in mini slide puller and pop she goes
andz327
Re: 125hp TDDI head
Postby wojciech » Wed Jan 10, 2018 4:07 pm
If you need buy used cylinder head, a biggest problem are not glow plugs, but the fact that cylinder head make always two unchangeable parts: lower main cylinder head and upper light frame, mounting camshafts in the cylibder head. This two part hasn' two different numbers, they have one common number. Wholes for camshafts are machine in factory in two joined parts - and from this moment they constitute one unchangeable part with one number.
So - if we take and mount this two elements from two different engines - we have only very little chance for good and long engine work. Sometimes halfs of whole for camshafte are displaced one to second nearly half milimeter. It can not work correctly. Sometimes it is no bad...
You should buy this two things together from one engine.
On the picture nr 1 - violet single triangle.
wojciech
Re: 125hp TDDI head
Postby karl » Wed Jan 10, 2018 7:02 pm
told you you would need a full head i have a complete secound hand one with cams £250.00 :D
karl
Tranny Lover!!!
Re: 125hp TDDI head
Postby karl » Sat Jun 09, 2018 9:28 pm
I have sent you a pm mate
and yes it still available :D
karl
Tranny Lover!!!
