Oil change in SE London
Postby ollinist » Fri Jan 12, 2018 5:37 pm
Hi,
I'm desperately searching for a shop in SE London to do a Oil & filter change. I don't need the full service.
I visited the National Tyres & autoCare in Greenwich, but unfortunately the van is to high for them.
So I'm looking for a shop who can handle a LWB high roof Transit and the same price region as NTA, ~ 60£.
Any Ideas?
ollinist
Re: Oil change in SE London
Postby boltondigger » Fri Jan 12, 2018 8:54 pm
have a go yourself ? loads of threads on it
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby joinerman » Fri Jan 12, 2018 9:54 pm
Piece of cake, lay underneath ( bet that's put you off ) with a container undo sump plug, leave to drain, refit sump plug, change filter & refill with oil, not literally fill though. lol
joinerman
Postby DodgeRover » Sat Jan 13, 2018 8:45 pm
Try Muttley on here he is SE London (ish).
No idea on prices but at least it would be done right.
DodgeRover
Postby ollinist » Mon Jan 15, 2018 1:41 pm
The work doesn't afraid me, even if it's cold and wet outside to lay below the van, the issue I have is more about the oil disposal. :)
ollinist
Postby wronghole » Mon Jan 15, 2018 2:32 pm
Pour the old oil back into a suitable can and go to your local municipal tip, most will take waste oil. I tip mine into a 30lt plastic container and when full empty it at my tip .
wronghole
Postby RustWidow » Mon Jan 15, 2018 10:38 pm
Our local recycling and refuse site (to give it its official name lol) will only let you deposit full receptacles, ie the oil cans. So check that out first.
RustWidow
Postby ned » Mon Jan 15, 2018 10:40 pm
You could always use the old oil on the underside of the van as rust protection :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby knobby1 » Tue Jan 16, 2018 12:43 am
ned wrote:You could always use the old oil on the underside of the van as rust protection :wink: N
Or....pour it over the top and set it alight..Oh sorry...that only applies to the 666 machines..! Sorry Ned. :lol: :wink: :mrgreen:
Postby Herts » Wed Jan 17, 2018 8:16 pm
Paint the fence with it.
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby knobby1 » Wed Jan 17, 2018 8:39 pm
Herts wrote:Paint the fence with it. Andy
But I've got a steel colour-bond fence.. :roll:
I'd like to tip it over the effing yapping pain in the ar$e dog over my back fence though :x Bloody thing never shuts up. :evil:
Postby ollinist » Wed Feb 07, 2018 3:12 pm
Did it myself in the end. Thanks for the advise. :) was easy.
ollinist
Postby knobby1 » Thu Feb 08, 2018 9:37 pm
ollinist wrote:Did it myself in the end. Thanks for the advise. :) was easy.
Yep, there's enough room to crawl under most Trannys...I hope you used latex gloves....that 'orrible diesel oil gets into your skin and stays there for days..! :roll:
