by wojciech » Tue Jan 16, 2018 4:28 pm
- 1984 - 1991, teeth height 2,5 mm, belt width 25,4 mm (nr 6138677)
- 1991 - 09/1997 teeth height 3,5 mm, belt width 25,4 mm (nr 1135355)
- 09/1997 - 2000 teeth height 3,5 mm, belt width 27,6 - 28,0 mm (nr 1135354).
Belts are inconvertible, only one situation is permissible: belt nr 1135355 can works instead belt nr 1135354 (if we have not correct belt).
