Timing Belt for a Mark V Transit
Postby sheenimark » Sun Jan 14, 2018 5:16 pm
Can any one advise if the timing belt is a belt or a chain. Thanks :)
sheenimark
Re: Timing Belt for a Mark V Transit
Postby Altransit » Sun Jan 14, 2018 8:42 pm
Mk5 diesel?
Belt, 28mm or 25mm depending on age :)
Postby sheenimark » Sun Jan 14, 2018 8:59 pm
sheenimark
Postby wojciech » Tue Jan 16, 2018 4:28 pm
- 1984 - 1991, teeth height 2,5 mm, belt width 25,4 mm (nr 6138677)
- 1991 - 09/1997 teeth height 3,5 mm, belt width 25,4 mm (nr 1135355)
- 09/1997 - 2000 teeth height 3,5 mm, belt width 27,6 - 28,0 mm (nr 1135354).
Belts are inconvertible, only one situation is permissible: belt nr 1135355 can works instead belt nr 1135354 (if we have not correct belt).
wojciech
